How to add a ServiceNow provider
What are Integrations?
What is a provider?
About ServiceNow providers
A ServiceNow provider is a dedicated provider that contains the connection details to your ServiceNow instance. You need to create a ServiceNow provider before you can use ServiceNow tiles..
Requirements for ServiceNow providers
- If you use a proxy server you may need to configure the proxy
(How to configure Dashboard Server to use a proxy) . - A ServiceNow account. It depends on the roles of the ServiceNow account you use for the ServiceNow provider what functions are available in the ServiceNow tile.
The permissions of the ServiceNow account you are using for your ServiceNow
We recommend using a service account, which means you create an account specifically to use with the ServiceNow
ServiceNow admin account
provider s.
sys_filter
sys_dictionary.*
sys_dictionary
sys_db_object
sys_ui_list
sys_db_object.*
sys_ui_list.*
The tile can be scoped
| ServiceNow admin account | ServiceNow non-admin account with ACLs | ServiceNow non-admin account without ACLs | |
| Being able to scope the tile | yes | yes (due to the ACLs) | yes (due to the web_service_admin role) |
| Being able to see all views in the View dropdown, not only the default view | yes | no | no |
| Being able to see all default filters, not only user-made ones | yes | yes (due to the ACLs) | no |
Where can I use ServiceNow providers?
The ServiceNow provider can be used with either the dedicated ServiceNow tile or the Web API tile (when you are using the Web API tile for ServiceNow).
The ServiceNow tile
Adding a ServiceNow provider
Under Integrations click on ServiceNow and type in a suitable name, e.g. ServiceNow.
instance url:
The instance URL should look something like
https://instancename.service-now.com/api/now/whereinstancenameis your instance. If/api/now/is not included as part of the instance URL then it will be automatically appended to this URL when the provider is created. If ServiceNow is installed on-premises, this may be something different.Note: This URL is prepended to every request URL.
client id and secret:
To get a client ID and secret from ServiceNow, you need to create an OAuth API endpoint for external clients in your ServiceNow account.
Note: If you already are using ServiceNow in Dashboard Server, you can re-use the client ID and secret you previously created. In this case, you can skip this step.
How to get a client ID and secret from your ServiceNow account- In your ServiceNow account in the Application Navigator (left-hand menu) go to System OAuth and click Application Registry.
Dashboard Serverand leave the other default settings as they are. - Once you've created the endpoint, open the entry to view the client ID and client secret. Click the padlock next to the client secret to see it.
username and password of the ServiceNow account you want to use.
Prerequisites for the ServiceNow accountHow the ServiceNow account affects the
ServiceNow tile
The permissions of the ServiceNow account you are using for your ServiceNowprovider affect what you can see and do in theServiceNow tile.We recommend using a service account, which means you create an account specifically to use with the ServiceNow
provider . You have different options for setting up this service account:ServiceNow admin account
provider s.
sys_filter
sys_dictionary.*
sys_dictionary
sys_db_object
sys_ui_list
sys_db_object.*
sys_ui_list.*
yes (due to the ACLs) yes (due to the web_service_admin role) Being able to see all views in the View dropdown, not only the default view yes no no Being able to see all default filters, not only user-made ones yes yes (due to the ACLs) no Click Save.
If the provider is not authorized it could be that some of the provider configuration is incorrect (for example the username, password, secret etc), or if you use a proxy it could be that the proxy is not configured. See How to configure Dashboard Server to use a proxy.
