After installing Dashboard Server you will be prompted to login and enter a license activation key. You will have been emailed an activation key (often called a license key), which is then activated against a Dashboard Server installation.
Free trial
Purchased Dashboard Server
Types of license keys
Trial license | This license allows for unlimited users and all features for a 30 day evaluation in your own environment and is available from here |
Primary Production license | This license should be used on your SquaredUp Production server. |
Test & Development license | This license is for your test environment so that you can experiment with configuration changes and new versions without affecting production. It is included free of charge with a purchase. |
Activating Dashboard Server when the server does not have internet access
Browse to
<SquaredUpURL>/activation
to get to your server's activation screen.Log in as an administrator. See How to make a user a Dashboard Server administrator
Click on offline activation. If Dashboard Server is already activated the link will show as offline reactivation.
If you see a message that the maximum number of activations has been exceeded see "License already activated" or "Maximum activations reached" or contact SquaredUp Support.
<SquaredUpURL>/InstallLicense
, and log in as an administrator.Once the file has uploaded click Next and then complete the setup wizard.
If you uninstall and reinstall on the same server you can reuse the same .bin file by browsing to <SquaredUpURL>/InstallLicense
. The .bin file cannot be used on a different server.
