How to activate your license
After installing Dashboard Server you will be prompted to login and enter a license activation key. You will have been emailed an activation key (often called a license key or activation key), which is then activated against a Dashboard Server installation.
If you have been asked to reactivate your existing license key, because it has been modified or extended, then you will need to reactivate your existing license (see How to reactivate your license).
If your web server cannot connect to the internet to activate then you can do an offline activation (see How to activate your license offline (manual activation)).
Use this article if you have been sent a new license activation key.
Free trial
Purchased Dashboard Server
Types of license keys
| Trial license | This license allows for unlimited users and all features for a 30 day evaluation in your own environment and is available from here |
| Primary Production license | This license should be used on your SquaredUp Production server. |
| Test & Development license | This license is for your test environment so that you can experiment with configuration changes and new versions without affecting production. It is included free of charge with a purchase |
How to Activate Dashboard Server
After deploying Dashboard Server, browse to the virtual machine using
https://DNSNameand log in as an admin user. See How to deploy Dashboard Server Azure Edition from the Azure Marketplace
Or you may need to browse tohttps://DNSName/activate
To find the DNS name in the Azure portal browse to the SquaredUp virtual machine > hover over the DNS name on the right of the screen > click the copy to clipboard button.
Alternatively:http://SquaredUpServer/SquaredUpv5/Activate
or for v4http://SquaredUpServer/SquaredUpv4/Activate
Paste your license key into the Activation screen.
Take care to use the correct license key, as many licenses only allow one activation.
Click the Activate button.
Complete the Dashboard Server setup wizard.
For more information on the setup wizard stages see How to deploy Dashboard Server Azure Edition from the Azure Marketplace or How to install Dashboard Server Azure Edition using the installer
Each Dashboard Server instance should have only oneDashboard Server license key installed. This is usually either a trial license, or - after purchasing Dashboard Server - the Primary
To check which license is being used by an instance of Dashboard Server, open Dashboard Server on a particular server by using the localhost address on the server itself or using the server name in the URL, for example https://SquaredUpServer/SquaredUpv5/
- In Dashboard Server click on the right-hand menu ☰ and then on system.
- Click on licensing .
Here you can remove a license, but if you accidentally remove the active license you may not be able to access Dashboard Server again without contacting SquaredUp Support.
Types of licenses
If you are having problems activating
Your Primary
If you uninstall and reinstall on the same server and you originally carried out an offline activation (as described in How to activate your license offline (manual activation))then you can reuse the same .bin file by browsing to
For more information see How to activate your license
You need a license activation key to install Dashboard Server Azure Edition. You will have received this by email following your purchase or free trial. If you do not have an activation key please contact SquaredUp Support.
For example:
That's fine, you can perform a manual or offline activation on another computer that has got internet access and then copy the .bin activation file onto the server. See How to activate your license offline (manual activation).
The activation key being used is not valid for the version of Dashboard Server.
Please contact SquaredUp Support with details of the problem and the activation key.
See How to reactivate your license
Anything else we can help with
Following activation
Browse to your Dashboard Server instance.
If you used the downloadable installer to install Dashboard Server:
By default, the URL to your Dashboard Server instance is: http://SquaredUpServer/SquaredUpInstance
SquaredUpServer is the name of the server where Dashboard Server is installed.
By default, SquaredUpInstance for version 5 is SquaredUpv5SquaredUpv4
If you deployed Dashboard Server from the Azure Marketplace:
The URL is https://DNSName of the virtual machine (VM) deployed.
