Dashboard Pack - Octopus Deploy
This dashboard gives an overview of deployments and tasks from Octopus Deploy
| Deployments (Donut) | High level view of all deployments |
| Tasks (Grid) | High level view of all tasks |
Create a Web API provider to connect with your Octopus Deploy environment.
Use the following settings:
Type Simple auth Name OctopusDeploy
URL Enter the base url for the Octopus API, i.e. https://octopus.company.com/api
default headers Enter your Octopus Deploy API key in the following format:
First box (name):
x-Octopus-ApiKeySecond box (value):Token( i.e. API-LKASJDLKAJDLKASLDKJ)
Note: When adding an OAuth provider you may get an message that the provider is not authorized if some of the provider configuration is incorrect (for example the username, password, secret etc), or if you use a proxy it could be that the proxy is not configured. See
How to configure Dashboard Server to use a proxy. Complete the provider fields, using your API provider's online documentation as a guide.
