Dashboard Pack - M365
This dashboard visualizes data produced by your organization’s M365 tenant so you can manage licenses, usage, capacity, and more. This dashboard will allow you to monitor key metrics for Microsoft 365 SharePoint, Exchange Online, and Teams so you can be proactive in assigning storage.
The dashboard connects to the Microsoft Graph API, which offers a broad set of functionalities for working with Azure. Microsoft 365 sits on top of Azure and can be managed via Graph API, too. The reports section of Graph API exposes usage insights of your M365 tenant and can be easily consumed and nicely presented.
| SharePoint Site Number Growth | Monitors SharePoint Online and displays the site number growth as a line graph to manage storage. |
| SharePoint Site Top Storage Usage | A bar graph displaying top five sites by storage usage to see exactly which sites are using the most storage. |
| Top Visited Pages | Displays the top five most visited pages in SharePoint Online. |
| Exchange Online Mailbox Count | Monitors M365 Exchange Online and displays the mailbox count as a line graph showing both the total count and the number of active mailboxes. |
| Exchange Online Mail Traffic | Displays how much mail is sent and how much is received in a line graph. |
| Outlook Platforms | Monitors which platforms are used to access Outlook – Mac, Windows, mobile, and web. The Donut shows percentages of all the traffic. |
| Teams Top Members | Top 5 of Teams with most members. |
| Teams Top External Members | Top 5 of Teams with most external members. |
| Teams Activity by Type | Displays when and how often the Teams activities Calls, Meetings and Messages have been used. |
Create an Azure Active Directory provider with settings as described in this blog article. Name this provider "AzureTest".
