Dashboard Pack - PagerDuty
This dashboard gives an overview of incidents and alerting from PagerDuty.
| Resolved (Summary Donut) | Resolved incidents |
| Triggered, Acknowledged, Resolved (Scalar) | Insight into the current incidents of each priority |
| Incidents Over Time (Line Graph and Sparklines) | Time series showcasing incidents over a time span (customizable and can use page timeframe) |
| Recent Alerts (Grid) | List of recent alerts (customizable and can use page timeframe). Also displays which integration alert has been triggered from |
The page timeframe is the timeframe setting a dashboard
Create a Web API provider to connect with your PagerDuty environment.
Use the following settings:
Type Simple auth Name PagerDuty
URL Enter the base url for the PagerDuty API, i.e. https://api.pagerduty.com/
default headers Enter your PagerDuty API token in the following format:
First box (name):
How to create a Web API provider for PagerDutyIn Dashboard Server navigate to the right-hand menu ☰ > system > Integrations
First box (name):
