Dashboard Pack - Uptime Robot
Uptime Robot is an uptime monitoring platform, providing a free tier to create up to 50 free monitors for Website, SSL, Port and Ping, as well as heartbeats to monitor reoccurring jobs. This dashboard gives an overview of monitoring configured using Uptime Robot’s website monitoring features.
| Response Times (Bar ) | Displaying current response times for our web tests |
| Status (Status Block) | Showing health of tests, URL, and response time |
| Configuration (Grid ) | Displaying configuration for the tests |
Create a Web API provider to connect with your Uptime Robot environment.
Use the following settings:
Type Simple auth Name UptimeRobot
URL Enter the base url for the UpTimeRobot API i.e. https://api.uptimerobot.com/v2/
Note: When adding an OAuth provider you may get an message that the provider is not authorized if some of the provider configuration is incorrect (for example the username, password, secret etc), or if you use a proxy it could be that the proxy is not configured. See
How to configure Dashboard Server to use a proxy. Complete the provider fields, using your API provider's online documentation as a guide.
Add your Uptime Robot API key to the tiles.
For the tiles to work with your Uptime Robot environment, you need to add your API key to each tile.
Open the headers & data panel.
Enter your Uptime Robot API key in the data field in the following format:
Name Value api_key Your Uptime Robot API key, see UptimeRobot Rest API documentation format json response_times 1
Publish the dashboard.
Team Folders, or visible to anyone even unlicensed users withSharing Dashboards with anyone - Open Access .
