Dashboard Pack - Kubernetes Monitoring dashboard (with Prometheus)
This dashboard visualizes the performance of a Kubernetes cluster by getting metrics from Prometheus using PromQL in the Web API and PowerShell tiles.
Basic cluster information displayed in a grid
Network traffic sent and received for the cluster
CPU, memory and disk utilization for the cluster
CPU, memory and disk used by each node in the cluster
The tiles on this dashboard automatically adjust the queries to Prometheus based of the page time frame being selected. The Rate and Step variables are handled in the PowerShell profile and can be amended as required.
Create a Web API provider to connect with Prometheus.
Use the following settings:
Type Basic Auth Name Prometheus
URL URL of your Prometheus instance API endpoint, for example https://<your-prometheus-url/api/v1/Username and password Enter the credentials for your Prometheus environment
Name Prometheus
Description Sets the Prometheus API endpoint, changes step and rate values based on the timeframe of the page, and gets the page timeframe start and end. Script Copy and paste the script below, replacing
<your-prometheus-url>with your Prometheus instance API endpoint. Modify the PowerShell profile to handle the authentication method required by your deployment of Prometheus.
PowerShell profile scriptCopy
# Set the end point of the Prometheus API endpoint
$uri = "https://<your-prometheus-url>/api/v1/query_range"
# Changes step and rate values based on the timeframe of the page.
switch ($timeFrame) {
"last1Hour" { $step = '60'; $timeago = -1; $rate = '2m' }
"last12Hours" { $step = '600'; $timeago = -12; $rate = '30m' }
"last24Hours" { $step = '900'; $timeago = -24; $rate = '1h' }
"last7Days" { $step = '1200'; $timeago = -168; $rate = '6h' }
"last30Days" { $step = '1800'; $timeago = -720; $rate = '1d' }
"last3Months" { $step = '7200'; $timeago = -2160; $rate = '1d' }
"last6Months" { $step = '10800'; $timeago = -4320; $rate = '7d' }
"last12Months" { $step = '21600'; $timeago = -8640; $rate = '7d' }
# Get the page timeframe start and end
$end = Get-Date -Date (Get-Date) -UFormat %s
$start = Get-Date -Date ((Get-Date).AddHours($timeago)) -UFormat %s
- Go to the PowerShell tab.
- Click add new profile.
- Enter the profile script.
- Click add profile.
