Dashboard Pack - Jira Health dashboard
This dashboard shows a quick view of the state of your next release and overall Jira project.
One of the main issues to overcome when returning a large number of items from Jira is that the API has a 100 issue limit. This is resolved here by using a PowerShell tile and making multiple API calls.
Release completion is calculated by total issues Closed or Merged, divided by the total issues in the release. This could be further fine tuned to only look at specific issue types that you care about by changing the API call in the script. Similarly on the Project side the Top 10 list (Web API) could be set to be any issue type by adjusting the API call. The trend line is calculated by creating an array.
Create a Web API provider to connect with your Jira environment.
Use the following settings:
Type Basic Auth Name Jira API basic
URL URL of your Jira instance API endpoint, for example https://<JIRA domain>.atlassian.net/rest/api/3/Username The Jira user account name you will use to access the API Password Paste in the new API token created according to How to create an API token from your Atlassian account
Name Jira PS
Description Contains an encoded version of the username and password pair that will be sent in the Header variable of the API, the Jira API URL for row links. Script Copy and paste the script below. Replace usernameandpasswordwith the credentials for the user account you are using to access the API, and replace<JIRA domain>with your Jira domain details to form the correct URL.
PowerShell profile scriptCopy
$user = "username"
$pass = "password"
$org = "https://<JIRA domain>.atlassian.net/rest/api/3/"
$pair = "$($user):$($pass)"
$encodedCreds = [System.Convert]::ToBase64String([System.Text.Encoding]::ASCII.GetBytes($pair))
$basicAuthValue = "Basic $encodedCreds"
$Headers = @{
Authorization = $basicAuthValue
- Go to the PowerShell tab.
- Click add new profile.
- Enter the profile script.
- Click add profile.
