Dashboard Pack - Pingdom dashboard
This dashboard gives an overview of Pingdom checks using PowerShell scripts against the Pingdom API
Monitor Health - Status block tile showcasing health and last response time
Monitor Status - Donut tile summarizing checks by status
Monitor by Type - Donut tile summarizing checks by check type
Monitor Last Response Time - Scalar tile values for single checks. Your chosen Pingdom check name should be added into the quotes in the tile script section:
$checkName = ''for example$checkName = 'website'.Last Response Time - Bar of all checks' last response time
Multiple Response Times - Line graph of two checks (easily adapted to include more than two checks) - Your chosen Pingdom check ID should be added into the quotes in the tile script section:
$checkId1 = ''and$checkId2 = ''for example,$checkId1 = '1234567'.Single Response Time - Line graph for single check -Your chosen Pingdom check ID should be added to the tile script section in the quotes:
$checkId1 = ''for example,$checkId1 = '1234567'.Monitors Detail - Full check output (some returned data hidden - use grid columns > show hidden columns in the tile to view all)
Pingdom check ID's and names are shown in the PowerShell grid tile titled Monitors Details at the bottom of the dashboard.
Name Pingdom
Description Sets the Pingdom API endpoint, changes step and rate values based on the timeframe of the page, and gets the page timeframe start and end. Script Copy and paste the script below. Modify the PowerShell profile to replace ***TOKEN GOES HERE***with your Pingdom API token without the asterix.
PowerShell profile scriptCopy
$url = "https://api.pingdom.com/api/3.1/"
$headers = @{
authorization = "Bearer ***TOKEN GOES HERE***"
- Go to the PowerShell tab.
- Click add new profile.
- Enter the profile script.
- Click add profile.
Finally you need to edit the dashboard to enter the Pingdom check IDs and names for the checks you wish to display.
Each tile that needs editing has a subheading showing what is needed.
Copy the checks ID or name you want from the PowerShell grid tile titled Monitors Details at the bottom of the dashboard. If you prefer, then you can find the check IDs and names in Pingdom as described below.
How to find the check IDs in PingdomBrowse to your Pingdom instance, and the check you are interested in.
The <check id> is the number shown in the URL:
Edit each tile and enter the required checks ID or name into the script section of the tile configuration.
So it looks like this, but with your own check IDs:
- Click Apply Changes > Done.
