After installing Dashboard Server you will be prompted to login and enter a license activation key. You will have been emailed an activation key (often called a license key), which is then activated against a Dashboard Server installation.
You need a specific Community Edition license activation key to install Dashboard Server Community Edition. This will be a different key to any other you might have received from Dashboard Server for other products. You will have received this by email with your free trial or purchase.
Activating Dashboard Server when the server does not have internet access
Browse to
http://SquaredUpServer/SquaredUpv5/activationto get to your server's activation screen.(where
SquaredUpServeris the name of the server where Dashboard Server is installed).Log in as an administrator on the server.
Click on offline activation. If Dashboard Server is already activated the link will show as offline reactivation.
If you see a message that the maximum number of activations has been exceeded see Troubleshooting licensing and activation or contact SquaredUp Support.
http://SquaredUpServer/SquaredUpv5/InstallLicense, and log in as an administrator on the server.Once the file has uploaded click Next and then complete the setup wizard.
If you uninstall and reinstall on the same server you can reuse the same .bin file by browsing to http://SquaredUpServer/SquaredUpv5/InstallLicense. The .bin file cannot be used on a different server.
