Dashboard Pack - Octopus Deploy
This dashboard gives an overview of deployments and tasks from Octopus Deploy
| Deployments (Donut) | High level view of all deployments |
| Tasks (Grid) | High level view of all tasks |
Create a Web API provider to connect with your Octopus Deploy environment.
Use the following settings:
Type Simple auth Name OctopusDeploy
URL Enter the base url for the Octopus API, i.e. https://octopus.company.com/api
default headers Enter your Octopus Deploy API key in the following format:
First box (name):
x-Octopus-ApiKeySecond box (value):Token( i.e. API-LKASJDLKAJDLKASLDKJ)
