Dashboard Pack - PagerDuty
This dashboard gives an overview of incidents and alerting from PagerDuty.
| Resolved (Summary Donut) | Resolved incidents |
| Triggered, Acknowledged, Resolved (Scalar) | Insight into the current incidents of each priority |
| Incidents Over Time (Line Graph and Sparklines) | Time series showcasing incidents over a time span (customizable and can use page timeframe) |
| Recent Alerts (Grid) | List of recent alerts (customizable and can use page timeframe). Also displays which integration alert has been triggered from |
The page timeframe is the timeframe setting a dashboard is currently using. When a user changes the page timeframe, all tiles that use the page timeframe will adapt to the new timeframe. Tiles that don't use the dynamic page timeframe aren't affected and won't change.
Create a Web API provider to connect with your PagerDuty environment.
Use the following settings:
Type Simple auth Name PagerDuty
URL Enter the base url for the PagerDuty API, i.e. https://api.pagerduty.com/
default headers Enter your PagerDuty API token in the following format:
First box (name):
How to create a Web API provider for PagerDutyIn Dashboard Server navigate to the right-hand menu ☰ > system > Integrations
First box (name):
