Dashboard Pack - SolarWinds Orion: Nodes and their health status
This dashboard shows data from SolarWinds Orion about nodes and their health status.
Create a Web API provider to connect with your SolarWinds environment.
Use the following settings:
Type Basic auth Name Solarwinds
URL Enter the URL to the Solarwinds API in the following format:
If your Solarwinds environment is installed on the same server as Dashboard Server: https://localhost:17778/SolarWinds/InformationService/v3/Json/
If your Solarwinds environment is installed on a different server:
https://server.domain.name:17778/SolarWinds/InformationService/v3/Json/
Username and password Enter the credentials for your SolarWinds environment.
Change the row links to point to your SolarWinds environment.
The Unhealthy Nodes and All Nodes tiles contain dynamic row links. To make the links work in your SolarWinds environment, you need to edit the link template in both tiles:
Open the grid options panel.
Exchange the
your-serverpart of the URL with the server name of your SolarWinds console.
How do dynamic links work?Dynamic links make use of dynamic properties which are inserted as part of the URL. This creates a template URL that will be resolved to an actual URL based on the items properties.
https://www.my-system/ticket-123, where123is the ticket ID, you can use the dynamic property that contains the ticket ID and enter the dynamic URLhttps://www.my-system/ticket-{{ticketID}}.
Publish the dashboard.
