Signing and security for sensitive tiles
When a tile queries data from external data sources, security measures are needed to prevent a malicious user from having Dashboard Server execute unauthorized queries and scripts.
The following tiles query data from external data sources and are considered sensitive tiles:
- SQL tiles query SQL databases
- Web API tiles query external Web APIs
- PowerShell tiles run PowerShell scripts
Signing for sensitive tiles
To make sensitive tiles that access external data sources more secure, Dashboard Serveruses signing. When a Dashboard Server admin creates a sensitive tile, it is automatically signed, meaning the JSON config of the tile contains a cryptographically hashed signature.
Signing fulfills two functions:
Since signing makes sure that a query or script has been created by a Dashboard Serveradmin, the SquaredUp server trusts them to be safe to run and show the results to users viewing a dashboard, even to unauthorized users viewing an Open Access dashboard.
Since tiles are only signed when they are created by Dashboard Serveradmins, signing prevents Dashboard Serverusers from creating or editing queries or scripts for tiles that access external data. Even if a user can author dashboards due to their Team Folder permissions, they can't create or edit queries and scripts in sensitive tiles.
Security factors for sensitive tiles
There are three factors to consider regarding security for those tiles:
Who can create and edit the query or script?
What identity is used to run the query or script?
Who can see the results?
By default, only Dashboard Serveradmins can create and edit dashboards and perspectives, which means only them can create and edit queries and scripts. When an admin creates or edits a sensitive tile, it is automatically signed.
If you are using Team Folders, you can allow Dashboard Server users to edit dashboards in a Team Folder by giving them the Author or Owner role for it. Being able to edit tiles in a dashboard means the user also has access to sensitive tiles:
they can view the queries and scripts in edit mode
they can attempt to create or edit queries or scripts in edit mode, but can't successfully do it due to signing. See What happens if a Dashboard Server user tries to create or edit queries or scripts?
What happens after a user tries to create or edit queries or scripts depends on your version of Dashboard Server.
In version 4.4 and below:
When a Dashboard Server user creates or edits a sensitive tile, the tile is permanently marked as untrusted. The tile no longer functions until a Dashboard Server admin restores the signing of the tile. Before restoring the signing, users can't see the result of queries and scripts in the tile, even if an administrator further modifies it and publishes it. This is to prevent the accidental execution of untrusted queries.
To restore the dashboard to working order for all users, an administrator can modify the JSON of the dashboard to re-enter signing into the _security field of the relevant tile(s) and publish the result:
Enter edit mode of the dashboard with the affected tile.
Edit the tile's JSON.
Find the_securityproperty with the valueSigning predicate redacted due to insufficient permissions.
Modify the
_securityproperty to have a value ofsigning.
Click the Apply changes button.
Save the JSON.
Publish the dashboard.
The query can now execute and the results are available to dashboard viewers.
In version 4.5 and above:
Any changes by a Dashboard Server user to sensitive queries or scripts are not saved. Users will see one or more of the following errors:
An error occurred. Current user does not have permissions to modify sensitive tiles
You do not have permission to author or modify sensitive queries
You do not have sufficient permissions to access this resource
After making disallowed edits to a sensitive query any change (to the query or the rest of the dashboard) cannot be saved. Any further changes to the rest of the dashboard made after the disallowed edits to the sensitive query will also be lost. The user has to click the invalid changes button and then discard to discard the disallowed changes.
Enabling a Dashboard Server user to create and edit queries and scripts
The easiest way to enable a user to create and edit sensitive tiles is to turn them into a Dashboard Server admin. In the rare case that you want the user to be able to create and edit sensitive tiles but don't want to make them a SquaredUp admin, you can give them permission to do so (and therefore permission to sign tiles).
Make sure the user has the Team Folder role Author or Owner for the dashboards you want them to be able to edit.
How to set the permissions for a Team Folder- In Dashboard Server, navigate to the Team Folder you want to edit.
Click on the view folder settings button at the top right of the page.
Click on the edit this folder button.
To set the permissions for this Team Folder, add a new user and give them a role or edit the role of an existing user.
Click save changes.
Give the user permission to sign tiles.
Note: This feature should be used with caution. If you give a user permission to sign tiles, they can write, edit and execute any query and script (SQL, Web API and PowerShell). This can result in sensitive information disclosure or even data loss.
How to give a Dashboard Server user permission to sign tilesLog on to the SquaredUp server.
Run Notepad as administrator (File, Run, type
notepad, right-click and select Run as administrator), and then open the following file from the Dashboard Server folder:\User\Packages\QueryAuthoring\User\access-control.json
For example, for Dashboard Server v5 the default folder location isC:\inetpub\wwwroot\SquaredUpv5The file should look similar to the following:
Copy{
"view": [],
"author": [],
"owner": []
}Add the user (or group) to the
authorproperty.To add a user, you need to enter the username or group. Note that \ separators should be entered as
\\insteadTo add a user, you need to enter the ID and display name of the user or group. Note that the ID can be found in Azure AD from the relevant object's Overview page as
Object Id.Copy{
"view": [],
"author": [
"mydomain\\myuser"
"owner": []
}Copy{
"view": [],
"author": [
"id": "2be16d89-db0d-4fcd-acc7-6ae843dc8a22",
"displayName": "Group Display Name"
"id": "56274654-5ba3-46b2-8fdc-1c7479524eb2",
"displayName": "user@domain.name"
"owner": []
}Save the file to the same location.
To see the change take effect in Dashboard Server either recycle the IIS application pool, or select reload from ☰ > system > Dashboards > Reload all content.
The users listed as author in the file will now have permissions to create and edit queries.
Only for version 4.4 and below: Giving a user permission to sign tiles does not affect dashboards that have already been authored by that user. If a user already authored sensitive tiles and caused them to be untrusted, the signing of those tiles must be restored. This can be done by either deleting and re-creating individual tiles or the entire dashboards, or by restoring the signing in the JSON of the affected tiles.
How to restore the signing of a tileTo restore the dashboard to working order for all users, an administrator can modify the JSON of the dashboard to re-enter
signinginto the_securityfield of the relevant tile(s) and publish the result:Enter edit mode of the dashboard with the affected tile.
Modify the
Save the JSON.
It depends on the tile and their settings how queries and scripts are run:
| Tile | Queries/Scripts are run as: |
| SQL tiles | Dashboard Server app pool identity (unless documented otherwise) |
| Web API tiles | Dashboard Server app pool identity (unless documented otherwise) |
| PowerShell tiles | Run As account of the tile (by default, Dashboard Server app pool identity) |
Example: If the Dashboard Server app pool identity is MY SERVICE ACCOUNT, queries will always be performed by MY SERVICE ACCOUNT on behalf of the user, regardless of which Dashboard Server admin created the query or which Dashboard Server user is viewing the dashboard.
Limiting or scoping the data available to this identity is one method of securing external data sources.
Known issues
In v4.5 and above dashboard edits after making disallowed changes to a sensitive query are lost
In v4.4 and below unsigned queries are untrusted until modified
Permission changes do not affect dashboards already authored
Modify the
Save the JSON.
Enabling Open Access can disable previously working queries
If a non-administrator enables a dashboard for Open Access (see ), any queries on the dashboard (even if they were authored by an administrator) will become untrusted and disabled in the process.
To amend this, an administrator has to restore the signing of the affected tiles.
Modify the
Save the JSON.
