CVE-2021-40091 - SSRF issue
CVE:CVE-2021-40091
An SSRF issue was discovered in SquaredUp for SCOM 5.2.1.6654.
What should you do?
| Product | Affected versions | Resolved versions |
| SCOMÂ Edition | Versions earlier than 5.3.1 | 5.3.1 and later versions |
| Azure Edition | Versions earlier than 5.3.1 | 5.3.1 and later versions |
| Community Edition | Versions earlier than 5.3.1 | 5.3.1 and later versions |
Acknowledgement
| 10.11.2021 | Initial release |
