CVE-2021-40094 - DOM-based stored cross-site scripting
CVE:CVE-2021-40094
Before Dashboard Server version 5.3.1, DOM-based XSS was possible. If successfully exploited, this vulnerability may allow attackers to inject malicious code into a user's device.
Fix
The browsercheck function has been improved to prevent DOM-based XSS.
What should you do?
SCOMÂ Edition | Versions earlier than 5.3.1 | 5.3.1 and later versions |
Acknowledgement
