Dashboard Pack - SQL Samples
This dashboard demonstrates how the same base SQL query could be used with each of Dashboard Server's visualizations. Each SQL visualization slightly modifies how the data from the OperationsManagerDW database is presented to target user requirements. For example, a Status Block to quickly show health or a spark line to show how something has changed over time. The same data source, seven different SQL visualizations!
Replace the connection string in each of the seven SQL tiles with the connection string to your own OperationsManagerDW database.
Open the connection panel.
Enter the connection string
global:dw.
Publish the dashboard.
Team Folders, or visible to anyone even unlicensed users withSharing Dashboards with anyone - Open Access .
