How to use the Surface tile
The Surface tile shows health state, performance metrics and other information on top of an image, such as a map.
How does the Surface tile work?
The Surface tile works by using a row perspective to show a row of data for each of the
The Surface tile supports a maximum of 25
Can I change what information is shown?
You can change the row perspective used by each individual
Can I create new row perspectives?
When cell tiles are unticked, the data is still returned, but it is hidden from view. To make the tile more efficient or for more customization you can create a new row perspective: How to create and modify row perspectives.
How to configure a Surface tile
Add a new tile to a dashboard or perspective and choose
Resources > Surface tile.
Scope:
Configure the scope to define the
resources you want to show, Scopedresources will appear straight away and can be dragged into position.The Surface tile supports multiple
resources types. The Surface tile can show a different row perspective for eachresources (whereas the Matrix tile can only display rows of data forresources of the same type with a common row perspective). The row perspective used by each object can be changed, see Display information below.The Surface tile supports a maximum of 25
resources per tile, so only the first 25 objects of a scope are shown.Configure the scope carefully to show the 25resources you need.
If you see the message "You do not have access to all of the tenants currently selected" or "Tenant ID could not be resolved"In a multi-tenant environment a user who does not have access to all tenants will see this message if they attempt to edit a scope containing tenants that they do not have access to. This may be because:
Symptoms
A tile scope shows:
Procedure
You can add multiple
items . To remove anitem click the x to the right of its name.Tip: Start typing and after two characters you'll see suggestions that match the name appear.
Filter by type:
Filter by type:
Filter by type:
databasesand selectingSQL databases.Show hidden types This works in the same way as the Show hidden types option in the Azure portal.
resource . A dynamic scope consists of two different states:the configuration of the scope in the tile (for example, "consider child objects of type logical disk for the currently viewed object")
resource you are currently viewing ("this object has 5 child objects of type logical disk")
resources you are viewing.On perspectives, you can scope tiles to:
this resource
other resources Gives you the normal, non-dynamic scope options you are used to when scoping tiles on dashboards. This means the tile will not dynamically adapt it's content to the currently viewed
resource , it will always show data for the staticresource picked here.Since the power of perspectives is that their tiles can show data for different
resources depending on whatresource is currently being viewed, you should only select this option when you are sure that there is no relationship between the desired scope and the currently viewedresource .Once the
resources appear on the image you can drag them into location, and customize the way the panels look.
Hide metrics - tick boxes allow you to hide/show individual metrics.
Change row perspective - the drop down arrow at the bottom of the panel allows you to change the row perspective being used. The drop down list shows all the row perspectives that match the individual
resource , and you can choose a different row perspective to see different metrics. For more information about creating new row perspectives see How to create and modify row perspectives.Show preview - allows you to view the tile without the editing controls, so you can see what it will look like in normal use.
Settings in the tile display panel:
Object size Change size of the panels. From the initial size set, the panels will scale with the image, as the tile or dashboard size changes. Object opacity Change how transparent the panels are. Label Change how the metric labels are shown in relation to the metric graph. Hide object name Tick this option if you wish to remove the resource name, if for example it's already shown on the image.Collapse mode The metrics from the row perspective are hidden by default. Clicking on the resource name (if shown) reveals the metrics, therefore clicking on theresource name to drilldown is disabled.Click done to save the tile.
