ODBC on-premise plugin
Connects to any on-premises ODBC data resource.
How to add an ODBC data source
The ODBC data source requires that you have already installed the ODBC driver you wish to use on the same machine as the SquaredUp agent.
Configure and deploy an agent
Add an ODBC data source in SquaredUp
Display Name:
Agent Group:
Connection String:
Each ODBC Data Source will require a different Connection String, with the format varying based on the ODBC driver type. See ODBC Connection String: Connecting to Your Database
Object Query (optional):
The ODBC Connection can create objects in the Knowledge Graph index and these can be used to create context sensitive objects and drill-downs.
Object QueryThese plugins support the creation of objects from a database query. The resulting table must contain sourceId, name, and type fields. Additional fields are allowed, and any non-null fields will be included with the object when imported into the Knowledge Graph.
A sample query result is below:
sourceId
name
type
initials
operating_system
abeLincoln
Abraham Lincoln
user
AL
server_1
Infra-SQL01.local
server
windows
In the above sample table two objects will be created in the Knowledge Graph. The first will be of type user and have a sourceId of abeLincoln and a single property for initials. The operating_system attribute will not be added to this object as it has a null property. The second object created will be a server with sourceId server_1 and a single property of operating_system.
Relationship Query (optional):
If you are creating objects with the Object Query set in the previous step, you can relate those objects in the Knowledge Graph.
Relationship QueryAlong with an Object Query an additional Relationship Query can also be used. The result of this query must contain the fields inV, outV, and label. The rows of this result will be converted to relationships in the Knowledge Graph.
outV
label
inV
abeLincoln
own
server_1
After the import is complete the two objects created from the Object Query will now be linked, with Abraham Lincoln owning Infra-SQL01.local
Click Add.
Using the ODBC data streams
Add a dashboard and go into the configuration of a tile.
Filter by the ODBC On-Premises.
Create a data stream by clicking on one of the customizable data streams.
Creating a data stream using a configurable data stream
Create a data stream using the configurable data stream form
When using the data source to create data streams you have the option to create three different query types, as detailed below. The use of dynamic {{mustache}} properties is supported and is detailed following the types.
Custom Table Query
This allows for any tabular data to be pulled into to SquaredUp and be displayed in a standard table.
Custom Metrics Query
This configurable data stream type allows for data to be displayed in a visual format, such as a line graph. When writing a query for use as a Metrics query, the below three columns are mandatory and all others will be ignored.
Column Name (case sensitive) | Content |
label | The label for the value passed in, for example ‘Percent Utilization’. Each distinct ‘label’ value will get its own line color which includes only values for that label. |
timestamp | A DateTime value of when this reading occurred |
value | A numerical non-null value to be visualized |
Custom State Query
This configurable data stream allows for data to be displayed as a state tile (Red, Yellow, or Green blocks). When writing a query for use in a State query the below three columns are mandatory and all others will be ignored.
label | The label for the state passed in, for example ‘Deliveries’. These ‘label’ values must be distinct and will each produce their own status block |
id | If this state will be tied to an object, then that object’s sourceId should be used, otherwise passing the ‘label’ value a second time will work effectively. |
state | The state of the labeled object, options are ‘Success’, ‘Warning’, ‘Error’, and ‘Unknown’ |
Mustache parameters
A mustache parameter is a dynamic value, the actual value will be inserted to replace the field in curly braces. For example, {{timeframe.start}} will insert the start time based on the timeframe configured within the tile, or {{name}} will insert the name of the object(s) in scope.
Check the relevant data source documentation to see which fields accept mustache parameters. See Plugins and Data Sources
Only scoped data streams are able to insert properties from objects in scope, such as
sourceIds,sourceIdandtargetNodes. They will also be able to use other properties such astimeframe.Global data streams are able to use other properties, such as
timeframe.
See Data Streams
Mustache parameters for unscoped and scoped data streams
timeframe
All of the properties in the calling event payload are passed through to the template builder with the addition of below three properties.
• durationSeconds
• durationMinutes
• durationHours
Example
Parameter | Replacement value | Type |
{{timeframe.start}} | 2022-03-13T19:45:00.000Z | string |
{{timeframe.unixStart}} | 1647200700 | number |
{{timeframe.end}} | 2022-03-14T19:45:00.000Z | string |
{{timeframe.unixEnd}} | 1647287100 | number |
{{timeframe.enum}} | last24hours | string |
{{timeframe.interval}} | PT15M | string |
{{timeframe.durationSeconds}} | 86400 | number |
{{timeframe.durationMinutes}} | 1440 | number |
{{timeframe.durationHours}} | 24 | number |
Select CustomerName, Order from dbo.Orders where orderDT > DateADD(mi, -{{timeframe.durationMinutes}},GetDate())
Mustache parameters for scoped data streams only
sourceIds
This is a unique property as some pre-processing occurs within the data source to modify the values. sourceIds will return a list of all the targeted nodes sourceId elements, concatenated with commas and string delimiters for TSQL friendly systems.
Example
{{sourceIds}} | 'idOne','idTwo','idThree' | string |
Select CustomerName, Order from dbo.Orders where customerId IN ({{sourceIds}})
sourceId
This will return the sourceId of the first target node in the query. While not as powerful as the sourceIds value, it works for systems that don't support TSQL syntax and will still allow drill-down behavior
Example
{{sourceId}} | idOne | string |
Select CustomerName, Order from dbo.Orders where customerId = '{{sourceId}}'
targetNodes
This property represents the targetNodes on the calling event with the small addition of a first and last property on the respective nodes. This allows for Mustache templates to do a couple tricks, as noted below.
Example
{{targetNodes.0.sourceId}} | idOne | string |
{{#targetNodes}}'{{sourceId}}'{{^last}},{{/last}}{{/targetNodes}} | 'idOne','idTwo','idThree' | string |
Select CustomerName, Order from dbo.Orders where customerId = '{{targetNodes.0.sourceId}}'
Select CustomerName, Order from dbo.Orders where customerId IN ({{#targetNodes}}'{{sourceId}}'{{^last}},{{/last}}{{/targetNodes}})
