Quest Foglight plugin
The Foglight plugin allows you to connect to the Quest Foglight data source, which is a database monitoring tool. See Quest: Foglight Support
Plugins connect SquaredUp to your data sources. There are lots of plugins available with new ones being made available regularly, see SquaredUp: Plugins. Plugins can be used to add new data sources from Data sources on the left-hand menu. Most data sources need credentials like an API key, access token or other authentication methods.
On-premises plugins allow you to connect to APIs hosted on-prem.
If there isn't a plugin available for your data source, then you can use the Web API plugin to connect to any HTTP API that returns JSON. Alternatively, you can build and customize your own plugin. Contact us for more information.
How to add a Foglight on-premises data source
Configure and deploy an agent
Add a Foglight data source to SquaredUp
Display Name:
Agent Group:
Enter your Foglight instance URL
To authenticate you can either use an API token OR enter a username and password.
How to create an API token in Foglight AdministrationCreate an API auth token from within Foglight > User Management > Set Auth Token:
Quest Foglight: How to use Rest API
Copy the token value and save a note of ready to use in the SquaredUp Foglight plugin form.
Ignore Certificate errors:
If you activate this checkbox the data source will ignore certificate errors when accessing the server. This is useful if you have self-signed certificates.
Ignore edges:
This will disable the graph edge import, useful for large instances where you may not need the graph information or if you re near your edge limit.
Install Sample Dashboards:
Using the Foglight data streams
Data streams are also installed with the data source see Tips for using the Foglight Data Streams
Create a data stream using the configurable data stream form see Using configurable data streams
There are eleven global data streams installed with this data source:
All Foglight Alarms
This data stream provides access to all active alarm data. Unlike other data streams it is affected by timeframe.
Click on Foglight under Data Source and then Global under Data Stream Type.
Click on the All Active Alarms data stream.
Host Alarms
This data stream provides access to Host alarm data for all hosts.
Click on the Host Alarms data stream.
Pick between the blocks, table, and scalar visualizations or shape the data.
Host Status
This data stream provides access to Host status data for all hosts.
Click on the Host Status data stream.
Choose the preferred visualization or shape the data.
Agents Alarms
This data stream provides access to Agent alarm data for all agents.
Click on the Agents Alarms data stream.
Agents Status
This data stream provides access to Agent status data for all agents.
Click on the Agents Status data stream.
AgentManagers Alarms
This data stream provides access to AgentManager alarm data for all agent managers.
Click on the AgentManagers Alarms data stream.
AgentManagers Status
This data stream provides access to AgentManager status data for all agent managers.
Click on the AgentManagers Status data stream.
Databases Alarms
This data stream provides access to Database alarm data for all databases.
Click on the Databases Alarms data stream.
Databases Status
This data stream provides access to Database status data for all databases.
Click on the Databases Status data stream.
Tablespaces Alarms
This data stream provides access to Tablespace alarm data for all tablespaces.
Click on the Tablespaces Alarms data stream.
Tablespaces Status
This data stream provides access to Tablespace status data for all tablespaces.
Click on the Tablespaces Status data stream.
Foglight API Endpoint
This data stream allows users to specify a specific API GET endpoint from which they want to pull data.
Scope to a Foglight Entity
Select Foglight API Endpoint
Enter a valid Foglight API GET endpoint (e.g.
alarm/current)
Scoped Foglight API Endpoint
This data stream allows for the specification of a specific API endpoint and supports mustache templating, allowing for dynamic customization. E.g. alarm/current/{{sourceId}}
Select Scoped Foglight API Endpoint
Define any mustache templating in the endpoint for dynamic customization
Topology Query
This global data stream allows users to configure a query string that will return data from a Foglight Query. This can be used to extend the functionality of the data source, queries such as !DBO_Listener_Status where (aggregateState > 0) (this will show any Listeners that have a non green state) allow someone to track and get status of servers or listeners that we don’t import.
Select Topology Query
Define a Foglight query (e.g.
!DBO_Database WHERE alarmAggregateTotalCount > 0)Optionally, set the Maximum Depth parameter to limit the depth of the returned topology.
Scoped Alarms and Status
For all Foglight imported objects there are two data streams, one to get a list of alarms and another to get the current status. (These are useful if someone wishes to focus on a specific few imported items in a tile) not really recommended to use these for large scopes, easier to use the global data streams and filter the results.
