Symptoms
When activating Dashboard Server you see:
or
Procedure
Your Primary license key can only be activated once.
If you are adding further SquaredUp servers to a multi-server / high availability environment you should use the Secondary license key for each subsequent server
If you are using your v3 activation key on v4, please see How to migrate from Dashboard Server SCOM Edition v3 to v4 for how to proceed.
If you uninstall and reinstall on the same server and you originally carried out an offline activation (as described in How to activate your license offline (manual activation))then you can reuse the same .bin file by browsing to
For more information see How to activate your license.
