Action buttons for dashboards and perspectives
About action buttons
Action buttons are customized buttons that you can add at the top of a dashboard
Open an internal link
An internal link within your Dashboard Server instance.
For example, when you want to link from an object's perspective to a dashboard that is relevant for that object. Internal links use only the part of the URL that comes after .../SquaredUpv[version number]/. For example, if the full URL to a dashboard is https://mysquaredup.com/SquaredUpv5/page/dashboard-enterprise-applications, you need to use /page/dashboard-enterprise-applications.Open a web link
How to add an action button to a dashboard or perspective
For dashboards: Go to the dashboard where you want to add the action button.For perspectives: If you want to add the action button to a specific perspective, go to
a resource that contains the perspective and choose this perspective. If you want to add the action button to all perspectives of a specifictype of resource , go toa resource of this type .Click on the edit button to go into edit mode.
If you leave the checkbox activated, the action button will be visible only on this one perspective.If you deactivate the checkbox, the action button will be visible on all perspectives for all resources of the same type as the resource you are currently viewing.
