How to use the Grid Designer
The Grid designer is available in the grid columns panel in
Grid visualizations. It allows you to easily add, hide, order, and customize columns of data that may come from any internal or external source.
Hiding a column
By default, when you configure a tile all columns will be displayed. To hide a column, simply click hide for each column you wish to hide.
Restoring hidden columns
If you have previously hidden some columns that you now want restored, you can click show all columns to show visible and hidden columns (the toggle will now read show visible columns only). Columns that are currently hidden will be grayed out and have the show option instead of hide.
Tip: Filtering columns in your query
The column modifications are performed client-side, so it's still most efficient to filter the columns directly in your query or script
Ordering columns
Changing the column order couldn't be easier, simply click and drag the gray ☰ icon to the left of the column name.
Changing the name of a column
If you want to change a column name, simply click on the existing column name in the grid options panel and enter the new name.
To restore the original name, simply delete your updated name and the column will revert to its original name.
Changing the way the data in a column is displayed
To format the way the data in a column is displayed, click edit to the right of a column to display the custom template box. You can then type your standard Dashboard Server 'mustache' syntax and click on done when you have the column looking exactly how you want it. If you want to preview the results before you're done, click anywhere outside the text box while editing it.
A { } icon will appear next to the column edit option to indicate that a custom template has been applied.
The mustache syntax is great for converting numbers, adding units, highlighting key values or performing any other customizations you may need. For more information on mustaches see How to use Custom Labels.
Original property name:
Adding custom columns
You can dynamically construct new columns based on the data returned by your tile, which is invaluable when dealing with data sources that only support simple data retrieval, or where the API does not return data in a simple tabular form (such as many JSON based Web APIs).
To add a custom column:
- Click the add button near the bottom of the grid columns panel.
- Click the column name and change the name from customcolumn1 to the name you want to give the column.
- In the data key path box, enter the (original) name of the column or path to the desired property in the returned data (this will depend on the API you are returning data from). If you need to access the values of multiple columns (i.e. concatenating two columns together) simply leave the box empty.
- Optionally, if you want to customize the display of the column, you can enter a mustache in the custom template box
- Click done when you have finished.
Custom columns have a pencil icon in the grid options panel to indicate they have been added by a dashboard author.
| Show Absolute |
| Show Time |
| Without Suffix |
| With Prefix |
Examples:
