How to use Custom Labels
Custom labeling allows you to specify exactly how you want resources to be displayed, using both static text and dynamic properties.
Supported tiles
Tiles that support custom labels come preconfigured with some useful labels and, in the case of Performance tiles, will even attempt to automatically select the most useful label based on the selected
The following tiles support
- Status
- Performance (Bar, Line graph, Sparklines)
- Matrix
- Image
- SQL
(Grid) - Web API
(Grid) - Azure Monitor Logs
(Grid) - App Insights
(Grid)
You can configure a custom label by configuring the label panel when creating or editing a supported tile. Below are some examples of using both a predefined and custom label.
The mustache helper
Custom labels use Mustache syntax to insert properties. If you're familiar with mustache, you can specify advanced labels that can transform properties prior to displaying them (such as showing only a portion of text, converting a number or reformatting a date).
For example you can use the javascript split method to separate properties into substrings to make the result more readable.
When specifying a mustache for a custom label, clicking the {{}} button or typing {{ brings up a helpful picker which shows all the properties of your selected resources, along with sample values.
Once the mustache helper is displayed, the list of properties will automatically filter based on what you type, allowing you to quickly find a property using a partial name or likely term. Clicking an item in the list will automatically insert that property into your label and complete the mustache.
Property names are case-sensitive and should be written as they appear in the mustache helperavailabilityStatus.location not AvailabilityStatus.location).
Note about using properties with hyphens from external APIs (for Web API, Elasticsearch, and Splunk tile)
Original property name:
Display virtual machines with a custom sub-label
You may wish to specify your own sublabel rather an use the default resource summary sublabel.
Create a Status resources (icons) tile.
On the scope panel select type and enter
Virtual Machines.Click on the sublabel panel.
Click on custom.
In the sublabel template paste in
Copy{{location}} {{properties.storageProfile.imageReference.offer}} {{properties.storageProfile.imageReference.sku}}
Click on done.
| Show Absolute |
| Show Time |
| Without Suffix |
| With Prefix |
Examples:
