How to use the ServiceNow tile
About ServiceNow tiles
The ServiceNow tile allows you to query incidents and change requests from ServiceNow and display this data in Dashboard Server.
The ServiceNow tile
For more information about using the Web API tile with ServiceNow see
How to configure a ServiceNow tile
If you don't already have a ServiceNow provider, you need to create one before you can configure a ServiceNow tile (How to add a ServiceNow provider).
Add a new tile to a dashboard or a perspective and choose the ServiceNow tile.
Select the visualization for your ServiceNow tile:
DonutShows the results in a donut shape.
Example:
ScalarA single value such as a number of customers or incidents.
Example:
GridA table of data, for example incidents or tickets.
Scope:
The scope section is optional, and allows you to specify a scope to narrow down the query
Requirements for using the scope in the ServiceNow tileIt depends on the ServiceNow account you are using for a provider if you can use the scope.
ServiceNow tile
The permissions of the ServiceNow account you are using for your ServiceNowprovider affect what you can see and do in theServiceNow tile.We recommend using a service account, which means you create an account specifically to use with the ServiceNow
provider . You have different options for setting up this service account:ServiceNow admin account
provider s.
sys_filter
sys_dictionary.*
sys_dictionary
sys_db_object
sys_ui_list
sys_db_object.*
sys_ui_list.*
The tile can be scoped
yes (due to the ACLs) yes (due to the web_service_admin role) Being able to see all views in the View dropdown, not only the default view yes no no Being able to see all default filters, not only user-made ones yes yes (due to the ACLs) no
If you see the message "You do not have access to all of the tenants currently selected" or "Tenant ID could not be resolved"In a multi-tenant environment a user who does not have access to all tenants will see this message if they attempt to edit a scope containing tenants that they do not have access to. This may be because:
Symptoms
A tile scope shows:
Procedure
You can add multiple
items . To remove anitem click the x to the right of its name.Tip: Start typing and after two characters you'll see suggestions that match the name appear.
Filter by type:
Filter by type:
Filter by type:
databasesand selectingSQL databases.Show hidden types This works in the same way as the Show hidden types option in the Azure portal.
resource . A dynamic scope consists of two different states:the configuration of the scope in the tile (for example, "consider child objects of type logical disk for the currently viewed object")
resource you are currently viewing ("this object has 5 child objects of type logical disk")
resources you are viewing.On perspectives, you can scope tiles to:
this resource
other resources Gives you the normal, non-dynamic scope options you are used to when scoping tiles on dashboards. This means the tile will not dynamically adapt it's content to the currently viewed
resource , it will always show data for the staticresource picked here.Since the power of perspectives is that their tiles can show data for different
resources depending on whatresource is currently being viewed, you should only select this option when you are sure that there is no relationship between the desired scope and the currently viewedresource .Provider:
Select your ServiceNow provider from the select provider drop-down and click next.
You can only use providers of the same type as the tile. Providers of other types won't be shown in the select provider drop-down.
Note: If you click on add new, you can create a new ServiceNow provider in a new tab. Click on reload after you created the new provider to be able to choose it from the drop-down.
Table:
Table:
Here you can choose if you want to get incidents or change requests (for any other data, you can't use the ServiceNow tile and need to use the Web API tiles, see How to use the Web API tile with ServiceNow).
View:
Here you choose the view that determines the set of columns which will be displayed. Views are created in ServiceNow and the list of views is populated from there.
If you only see the non-admin default view in the View dropdownIt depends on the ServiceNow account you are using for a provider if you can see all the available views or only the non-admin default view in the View dropdown.
ServiceNow tile
provider s.
sys_filter
sys_dictionary.*
sys_dictionary
sys_db_object
sys_ui_list
sys_db_object.*
sys_ui_list.*
yes (due to the ACLs) yes (due to the web_service_admin role) Being able to see all views in the View dropdown, not only the default view yes no no Being able to see all default filters, not only user-made ones yes yes (due to the ACLs) no Filter:
Here you choose a filter to restrict the query to certain items. You'll see default filters from ServiceNow and filters that have been created by users in ServiceNow.
If you only see user-created filters but no default filtersIt depends on the ServiceNow account you are using for a provider if you can see the default filters.
ServiceNow tile
provider s.
sys_filter
sys_dictionary.*
sys_dictionary
sys_db_object
sys_ui_list
sys_db_object.*
sys_ui_list.*
yes (due to the ACLs) yes (due to the web_service_admin role) Being able to see all views in the View dropdown, not only the default view yes no no Being able to see all default filters, not only user-made ones yes yes (due to the ACLs) no Configure the settings for the visualization you chose:
Settings for ScalarsScalar
Conditional formatting:
For example:
For example:
For example:
Display:
ServiceNow incidents:
Settings for DonutsDisplay
Size mode:
Display mode:
Settings for GridsDisplay
Limit:
Allows you to change the limit for the number of rows of data returned (default is 20).
Sort by:
Allows you to sort the data by a column in ascending or descending order. The Sort option uses the many incident fields, and you can sort by one of them even if that field is not currently displayed in your results table. To make this more clear you may like to reference this in the tile title, for example
Incidents, sorted by priority.Click done to save the tile.
FAQs
Why can't I find the provider I created in the dropdown list?
If you are unable to see your provider in the list check that it is a servicenow provider. Any other types of providers will not be shown in the dropdown.
How do I query data other than Incidents or Change Requests ?
The ServiceNow tile can only show Incidents or Change Requests. If you wish to query other tables use the Web API tile to query the ServiceNow API instead of the ServiceNow tile (see How to use the Web API tile with ServiceNow).
How do I create a new view or filter ?
The list of views and filters is pulled from ServiceNow. When you create any new views and filters in ServiceNow they will be available in Dashboard Server.
