How to use the Resources tile
The Resources tile contains two different kinds of tiles:
The Matrix tile shows health state, performance metrics and other information for a list of monitored
resources .The Resources Summary tile allows you to show a summary of resources, resource groups and subscriptions.
How to configure a Resource tile
Create a new tile on a dashboard or perspective and select the Resource tile.
Choose the type of Resource tile you want to configure:
Matrix
See How to use the Matrix tile
Summary
Summary ScalarThe Summary Scalar visualization allows you to show the total number of all resources in a scope. For example you might set the scope to a particular subscription, then filter by type to show virtual machines and change the unit to 'VMs'.
Summary GridThe Summary Grid visualization allows you to show a table representation of the total number of resources for the scope and grouping you have specified. You can also group and sort the table.
Summary BarThe Summary Bar visualization shows you a graph representation of the total number of resources for the scope and grouping you specify.
Scope:
Select the scope for your tile.
If you see the message "You do not have access to all of the tenants currently selected" or "Tenant ID could not be resolved"In a multi-tenant environment a user who does not have access to all tenants will see this message if they attempt to edit a scope containing tenants that they do not have access to. This may be because:
Symptoms
A tile scope shows:
Procedure
You can add multiple
items . To remove anitem click the x to the right of its name.Tip: Start typing and after two characters you'll see suggestions that match the name appear.
Filter by type:
Filter by type:
Filter by type:
databasesand selectingSQL databases.Show hidden types This works in the same way as the Show hidden types option in the Azure portal.
resource . A dynamic scope consists of two different states:the configuration of the scope in the tile (for example, "consider child objects of type logical disk for the currently viewed object")
resource you are currently viewing ("this object has 5 child objects of type logical disk")
resources you are viewing.On perspectives, you can scope tiles to:
this resource
other resources Gives you the normal, non-dynamic scope options you are used to when scoping tiles on dashboards. This means the tile will not dynamically adapt it's content to the currently viewed
resource , it will always show data for the staticresource picked here.Since the power of perspectives is that their tiles can show data for different
resources depending on whatresource is currently being viewed, you should only select this option when you are sure that there is no relationship between the desired scope and the currently viewedresource .Configure the settings for your visualization:
Settings for ScalarsScalar
Conditional formatting:
For example:
For example:
For example:
Display:
ServiceNow incidents:
Settings for GridsGrouping
Grouping
Allows you to control how the information is counted and displayed.
Note: If you've scoped to a resource type, such as Virtual Machines, then you should use another grouping method, such as resource group, tag, or custom.
Custom grouping:
Custom grouping allows you to group the resources being shown by any property or combination of properties, for example
{{location}}. You need to specify the properties just like you would do when you're creating a custom label, see How to use Custom Labels.Note: When the tile is scoped to a resource type or the resource type filter is set, additional properties become available for custom grouping. For example, you can define a label that includes the location property (always available) and the VM size property (only available when the scope is filtered to Virtual Machines) to group VMs by their location and size.
The Summary Grid below is grouped by type:
Sort
If you activate the checkbox limit number of results displayed you can limit the results to a number of results (from the top).
Settings for Bar GraphsGrouping
Custom grouping:
The Summary Bar visualization below is scoped to a subscription which is filtered by type to virtual machines. It is then grouped by custom > {{location}}:
Sort
Data Range
Click done to save the tile.
Walkthrough: Using the Summary Grid tile to show a count of all virtual machines by VM size
This walkthrough shows you how to add a Summary Grid visualization to a dashboard.
Create a new tile and click Resources.
Click on the Summary Grid button.
In the scope panel add a resource group or subscription. Tick filter by type and in the box type
Virtual machines.In the grouping section click custom. In the label box type
location / VM size. We're going to create a custom label.In the value box copy and paste the following:
Copy{{location}} / {{properties.hardwareProfile.vmSize}}The mustache helper button to the right of the value box shows all the options available along with an example value. Instead of coping the mustache syntax above, you could select
{{location}}from the dropdown list. Then type/and then click the mustache button again and select from the dropdown:{{properties.hardwareProfile.vmSize}}
In sort check that value and descending are selected.
Click done.
