How to use the Surface tile
The Surface tile shows health state, performance metrics and other information on top of an image, such as a map.
How does the Surface tile work?
The Surface tile works by using a row perspective to show a row of data for each of the
The Surface tile supports a maximum of 25
Can I change what information is shown?
You can change the row perspective used by each individual
Can I create new row perspectives?
When cell tiles are unticked, the data is still returned, but it is hidden from view. To make the tile more efficient or for more customization you can create a new row perspective: How to create and modify row perspectives.
How to configure a Surface tile
Add a new tile to a dashboard or perspective and choose
the Surface tile.
Scope:
Configure the scope to define the
objects you want to show, Scopedobjects will appear straight away and can be dragged into position.The Surface tile supports multiple
objects types. The Surface tile can show a different row perspective for eachobjects (whereas the Matrix tile can only display rows of data forobjects of the same type with a common row perspective). The row perspective used by each object can be changed, see Display information below.The Surface tile supports a maximum of 25
objects per tile, so only the first 25 objects of a scope are shown.Use the list or advanced scoping options to configure the scope to show the 25objects you need.
List List allows you to select one or more objects or groups.
You can add multiple
objects and groups . To remove anobject or group click the x to the right of its name.Tip: Start typing and after two characters you'll see suggestions that match the name appear.
Tips for using wildcards when searching for objects or groupsBy default searching will look for the top 10 items containing the words listed in the search. If you wish to create a more specific search you will need to use wildcards (*).
Group Group allows you to select members of a specific group. Only one group can be selected.
Advanced Advanced allows you to select a group, class or both. You must at least define either a group or class. You can define both. You can also use criteria to narrow down your selection.
Group:
Class:
Criteria:
Examples for commonly used criteriaObjects you would like to see Criteria Objects with particular text in their name DisplayName like '%Server1%'Objects starting with a particular string DisplayName like 'test%'All objects in maintenance mode InMaintenanceMode = 'TRUE'Only healthy objects HealthState = 1Objects with a health state in SCOM of 0, an unknown health state (uninitialized), a gray health state icon with a question mark. HealthState = 0Objects that are not healthy HealthState != 1Objects in critical state HealthState = 3Objects in critical or warning state HealthState = 2 or HealthState = 3To show all gray uninitialised objects HealthState = 0 OR HealthState IS NULLAll objects not in maintenance mode InMaintenanceMode != 'TRUE'Objects where the parent agent is offline IsAvailable='false'Objects that are offline, in maintenance or state unknown IsAvailable='false' OR InMaintenanceMode=1 OR HealthState=0Computers with a particular OS OSVersion = '6.3.9600'List objects by name and filter by HealthState (Name like '%Server3%' OR Name like '%Server4%' OR Name like '%Server2%') AND HealthState=3List objects by SCOM Id and filter by HealthState Id IN ('7021174b-9e5d-5fbf-878a-42b9f0bf6f4a', '9bd4a1cc-f07a-0e36-b37d-d9ee974e0f3c') AND HealthState=3Exclude object from the Group specified DisplayName not like '%server3%'Exclude objects from the Group specified (DisplayName NOT LIKE '%server3%') AND (DisplayName NOT LIKE '%server4%')For more information see:
objects you are viewing.Suggestions
Walkthrough: Editing a scope suggestion to make it work for all EAsEnterprise Applications are designed so that you can map out the servers that make up the application. You can then configure tiles to show information related to just the servers on the EA's map. When you create a perspective that will be used for all EAs, you need to make sure that you scope the tiles so that they work for any EA. When you start with a suggestion, the tile's scope only works for the one EA you're currently looking at, and this is why you need to edit the scope:
This /<YourApplicationName> Map / ... / Windows ComputerThe above will scope the tile to all the objects of class Windows Computer on this EAs map.
This / FinanceXS / ... / Windows Computer. Once chosen this scope will show all the Windows computers shown on the applications map.
Click on the text
<YourApplicationName> Map (children)which is your first scope step. This will expand the scope step so you can edit it.
<YourApplicationName> Mapby clicking the cross x next to it.
Start typing
Enterprise Application - Mapand select this from the list to add this class. This is so that this tile scope will work for all EAs, rather than just this one EA.
- The scope is now configured to show all the Windows computers on the EA's map, whichever EA you happen to be viewing with the perspective.
How to read the suggestionsYou can pick between "this object" and objects that are related to this object as parents, children or siblings. The suggestions for children are written as paths that follow the SCOM object tree structure, parents and siblings can be identified by the word parent or sibling in the suggestion.
This / child/child/class of objectThe dynamic scope will be resolved to children of the object currently viewed.
Example:
This / IIS Web Server / *selects all objects of any class in the level belowThis / IIS Web Server.This / child/ ... /class of objectThe dynamic scope will be resolved to children of the object currently viewed.
Example:
This / Sales App Map / ... / Windows Computerselects all objects of the class Windows Computer in theThis / Sales App Mappath.Parent class of objectThe dynamic scope will be resolved to parents of the object currently viewed. Sibling class of objectThe dynamic scope will be resolved to siblings of the object currently viewed. Show more triangle next to a suggestion
Example for navigating suggestions in an EAIf you are looking at an EA, the path to find all windows computers in that EA may read
Map / ... / Windows Computer. It returns all objects of the Windows Computer class contained within all of the paths underMap.To narrow the scope down, you can click on the triangle to expand the suggestion and select one of the more specific paths. If you select
Map / Web / Windows Computeryou will find all objects of the Windows Computer class in the pathMap / Web.If you choose the option
Map / *you'll find all objects contained in the map. If you extend this suggestion by clicking on the triangle, you'll see suggestions to select all objects in a more specific path, for exampleMap / Web / *.
Custom
How to pick a simple relation (one step through the SCOM model)At the top, you'll see the name of the object you are currently looking at. Now you can choose if you want to pick parents or children of that object, and if this parent or child relation should be considered only one level up or down the SCOM model or through all levels.
Class:
Criteria:
Example for picking a simple relationFor example, for a perspective created for the group IIS8 Computer Group adding a Status tile scoped to show children with a class of
objectwill show the group members, i.e. the members of the IIS8 Computer Group.
How to pick advanced relations (multiple steps through the SCOM model)If you need to traverse a more advanced SCOM object model like an EA, you can use the + button to add more steps. This creates a scope that can go through any kind of path of the SCOM object model.
Class:
Criteria:
Other specific objects
objects depending on whatobject is currently being viewed, you should only select this option when you are sure that there is no relationship between the desired scope and the currently viewedobject .Once the
objects appear on the image you can drag them into location, and customize the way the panels look.
Hide metrics - tick boxes allow you to hide/show individual metrics.
Change row perspective - the drop down arrow at the bottom of the panel allows you to change the row perspective being used. The drop down list shows all the row perspectives that match the individual
object , and you can choose a different row perspective to see different metrics. For more information about creating new row perspectives see How to create and modify row perspectives.Show preview - allows you to view the tile without the editing controls, so you can see what it will look like in normal use.
Settings in the tile display panel:
Object size Change size of the panels. From the initial size set, the panels will scale with the image, as the tile or dashboard size changes. Object opacity Change how transparent the panels are. Label Change how the metric labels are shown in relation to the metric graph. Hide object name Tick this option if you wish to remove the object name, if for example it's already shown on the image.Collapse mode The metrics from the row perspective are hidden by default. Clicking on the object name (if shown) reveals the metrics, therefore clicking on theobject name to drilldown is disabled.Click done to save the tile.
