How to use the SLA tile
Overview
The SLA tile displays gauges showing the availability of SCOM objects, such as servers or applications, based on your SCOM Monitor Service Level Objectives (SLOs).
How to configure an SLA tile
Before the SLA tile can be used, you must have one or more Monitor SLOs created in your SCOM management group.
How to create a Monitor Service Level Objective (SLO) in your SCOM console- Open the SCOM Operations Console.
- Go to Authoring workspace (Authoring tab on bottom left).
- Select Authoring > Management Pack Objects > Service Level Tracking in the left-hand tree view.
- Click Create in the right-hand task pane.
On the General page, enter the following details and click Next:
Name:Service Availability
Description:
<leave blank>- On the Objects to Track page click Select... next to Targeted class
- Set the Search result filter dropdown to Distributed Application
- In the list, select Service (from System Library). Click OK
- Ensure the Scope is set to All objects of the targeted class
- Click the New button to create a new management pack, for example
SlaTest On the Service Level Objectives page click Add > Monitor state SLO.
Dashboard Server does not support Collection Rule service level objectives.
Enter the following details and click OK
Service level objective name:Availability
Targeted class:Service
Monitor:Availability
Service level objective goal:99.000
Specify states:Critical is checked
Dashboard Server does not support unmonitored, and it should not be ticked.
- Click Next. On the Summary page, click Finish
Add a new tile to a dashboard or perspective and choose the SLA tile.
Scope:
List List allows you to select one or more objects or groups.
You can add multiple
objects and groups . To remove anobject or group click the x to the right of its name.Tip: Start typing and after two characters you'll see suggestions that match the name appear.
Tips for using wildcards when searching for objects or groupsBy default searching will look for the top 10 items containing the words listed in the search. If you wish to create a more specific search you will need to use wildcards (*).
Group Group allows you to select members of a specific group. Only one group can be selected.
Advanced Advanced allows you to select a group, class or both. You must at least define either a group or class. You can define both. You can also use criteria to narrow down your selection.
Group:
Class:
Criteria:
Examples for commonly used criteriaObjects you would like to see Criteria Objects with particular text in their name DisplayName like '%Server1%'Objects starting with a particular string DisplayName like 'test%'All objects in maintenance mode InMaintenanceMode = 'TRUE'Only healthy objects HealthState = 1Objects with a health state in SCOM of 0, an unknown health state (uninitialized), a gray health state icon with a question mark. HealthState = 0Objects that are not healthy HealthState != 1Objects in critical state HealthState = 3Objects in critical or warning state HealthState = 2 or HealthState = 3To show all gray uninitialised objects HealthState = 0 OR HealthState IS NULLAll objects not in maintenance mode InMaintenanceMode != 'TRUE'Objects where the parent agent is offline IsAvailable='false'Objects that are offline, in maintenance or state unknown IsAvailable='false' OR InMaintenanceMode=1 OR HealthState=0Computers with a particular OS OSVersion = '6.3.9600'List objects by name and filter by HealthState (Name like '%Server3%' OR Name like '%Server4%' OR Name like '%Server2%') AND HealthState=3List objects by SCOM Id and filter by HealthState Id IN ('7021174b-9e5d-5fbf-878a-42b9f0bf6f4a', '9bd4a1cc-f07a-0e36-b37d-d9ee974e0f3c') AND HealthState=3Exclude object from the Group specified DisplayName not like '%server3%'Exclude objects from the Group specified (DisplayName NOT LIKE '%server3%') AND (DisplayName NOT LIKE '%server4%')For more information see:
Scope tips and examples for dashboardsSLA-specific examples:
To show the SLA of a group itself, use the list option and type in the name of your group.
To show the SLA of members of a group use the group option with your group name.
General examples:
What you want to select What to use as a scope All your Distributed Applications (DAs) In the advanced section, use a class of either service (system.service) or user created distributed application
Only your Enterprise Applications (EAs) In the advanced section, use a class of Enterprise Application (Base)
objects you are viewing.Suggestions
Walkthrough: Editing a scope suggestion to make it work for all EAsEnterprise Applications are designed so that you can map out the servers that make up the application. You can then configure tiles to show information related to just the servers on the EA's map. When you create a perspective that will be used for all EAs, you need to make sure that you scope the tiles so that they work for any EA. When you start with a suggestion, the tile's scope only works for the one EA you're currently looking at, and this is why you need to edit the scope:
This /<YourApplicationName> Map / ... / Windows ComputerThe above will scope the tile to all the objects of class Windows Computer on this EAs map.
This / FinanceXS / ... / Windows Computer. Once chosen this scope will show all the Windows computers shown on the applications map.
Click on the text
<YourApplicationName> Map (children)which is your first scope step. This will expand the scope step so you can edit it.
<YourApplicationName> Mapby clicking the cross x next to it.
Start typing
Enterprise Application - Mapand select this from the list to add this class. This is so that this tile scope will work for all EAs, rather than just this one EA.
- The scope is now configured to show all the Windows computers on the EA's map, whichever EA you happen to be viewing with the perspective.
How to read the suggestionsYou can pick between "this object" and objects that are related to this object as parents, children or siblings. The suggestions for children are written as paths that follow the SCOM object tree structure, parents and siblings can be identified by the word parent or sibling in the suggestion.
This / child/child/class of objectThe dynamic scope will be resolved to children of the object currently viewed.
Example:
This / IIS Web Server / *selects all objects of any class in the level belowThis / IIS Web Server.This / child/ ... /class of objectThe dynamic scope will be resolved to children of the object currently viewed.
Example:
This / Sales App Map / ... / Windows Computerselects all objects of the class Windows Computer in theThis / Sales App Mappath.Parent class of objectThe dynamic scope will be resolved to parents of the object currently viewed. Sibling class of objectThe dynamic scope will be resolved to siblings of the object currently viewed. Show more triangle next to a suggestion
Example for navigating suggestions in an EAIf you are looking at an EA, the path to find all windows computers in that EA may read
Map / ... / Windows Computer. It returns all objects of the Windows Computer class contained within all of the paths underMap.To narrow the scope down, you can click on the triangle to expand the suggestion and select one of the more specific paths. If you select
Map / Web / Windows Computeryou will find all objects of the Windows Computer class in the pathMap / Web.If you choose the option
Map / *you'll find all objects contained in the map. If you extend this suggestion by clicking on the triangle, you'll see suggestions to select all objects in a more specific path, for exampleMap / Web / *.
Custom
How to pick a simple relation (one step through the SCOM model)At the top, you'll see the name of the object you are currently looking at. Now you can choose if you want to pick parents or children of that object, and if this parent or child relation should be considered only one level up or down the SCOM model or through all levels.
Class:
Criteria:
Example for picking a simple relationFor example, for a perspective created for the group IIS8 Computer Group adding a Status tile scoped to show children with a class of
objectwill show the group members, i.e. the members of the IIS8 Computer Group.
How to pick advanced relations (multiple steps through the SCOM model)If you need to traverse a more advanced SCOM object model like an EA, you can use the + button to add more steps. This creates a scope that can go through any kind of path of the SCOM object model.
Class:
Criteria:
Other specific objects
objects depending on whatobject is currently being viewed, you should only select this option when you are sure that there is no relationship between the desired scope and the currently viewedobject .SLO selection:
Click on the drop down list and select the Monitor SLO from SCOM that you wish to use.
The slo selection drop down only lists the Monitor SLOs from SCOM.
Dashboard Server does not support Collection Rule SLOs, or the unmonitored state which should not be ticked in the Monitor SLO configuration.
Timeframe:
This is the timeframe over which the SLA will be calculated. Hourly aggregated data will be used if it exists for the whole of the interval, if not then daily aggregated data is used.
You can either choose a specific timeframe or allow the tile to adapt to the page timeframe.
Style:
Here you can define how the SLA gauges are displayed.
tile (large SLA gauge, more details, useful for a large impact wallboard):
inline (smaller SLA gauge, list format to display more objects):
Visualization:
Allows you to remove the status icon, label or SLA gauge.
Label:
Allows you to change the label next to the status icon. You can also create a custom label (see How to use Custom Labels).
Click done to save the tile.
Troubleshooting
If when displaying the status and SLA of groups themselves (adding groups to scope > list for example) one or more groups have missing SLA gauges and the health status is shown as gray with a question mark, this means that the group does not have a Dependency Roll Up Monitor.
Dashboard Server pulls service level data from the Operations Manager Data Warehouse. To verify that the data shown in Dashboard Server matches that shown in SCOM, you can run a Service Level Tracking Summary Report (see How to run a Service Level Tracking Summary Report in SCOM).
Both SquaredUp and SCOM Reporting pull data from the Data Warehouse, so any inconsistencies in figures are usually due to configuration differences.
Check that both SquaredUp and the Service Level Tracking Summary Report are using the same SLO.
In Dashboard Server check the SLO selection section of the SLA tile configuration:
The SLO is specified in the Service Level Tracking Summary Report:
Check the configuration of the SLO (see How to check the configuration of a Service Level Objective in SCOM). Specifically, that Unmonitored is not ticked.
Check that your SCOM report is using the same timeframe as Dashboard Server.
In Dashboard Server if the tile timeframe is set to use page timeframe then the user can change the timeframe from the default of 12 hours using the buttons at the top of the page:
If the tile timeframe is set to specific timeframe then if a user clicks the page level times at the top of the page, the timeframe will not change:
Check that the timeframe in the SCOM report matches that being used in Dashboard Server:
Check that your SCOM report is using the same Data Aggregation as Dashboard Server for the timeframe.
Data Aggregation setting in the SCOM report:
Dashboard Server uses hourly data by default as long as it is available for the whole reporting timeframe, otherwise it uses daily data. Whether hourly data is available for the whole timeframe will depend on your Data Warehouse data retention settings (see How to optimise the Data Warehouse - 5 Point Plan). For a timeframe of 12 or 24 hours it will probably be using hourly data aggregation, for timeframes over 2 days (i.e. 7 days, 30 days, 3 months, 6 months, 12 months) SquaredUp will be probably be using daily data.
- If you are using an Availability report (see How to create an Availability Report in SCOM) check that the downtime state options match those specified in the SLO. See How to check the configuration of a Service Level Objective in SCOM. Run a Service Level Tracking Summary Report on the SLO (see How to run a Service Level Tracking Summary Report in SCOM).
- Change to an SLO that is working on another dashboard
- On the SCOM server restart the System Center Data Access Service.
