How to use the Web API tile with ServiceNow
This article covers how to use the Web API tile to query data from ServiceNow and display this data in Dashboard Server.
The ServiceNow tile
You can also watch the Webinar: Web API and ServiceNow
For more information about using the dedicated ServiceNow tile see How to use the ServiceNow tile.
This article covers these areas:
- Prerequisites
- Configuration in ServiceNow
- Adding ServiceNow as a Web API provider in Dashboard Server
- Walkthrough: Configuring the Web API tile for ServiceNow
Prerequisites
- Dashboard Server 4.4 or above.
- If you use a proxy server you may need to configure the proxy
(How to configure Dashboard Server to use a proxy) . - A ServiceNow account. It depends on the roles of the ServiceNow account you use for the ServiceNow provider what functions are available in the ServiceNow tile.
The permissions of the ServiceNow account you are using for your ServiceNow
We recommend using a service account, which means you create an account specifically to use with the ServiceNow
ServiceNow admin account
provider s.
sys_filter
sys_dictionary.*
sys_dictionary
sys_db_object
sys_ui_list
sys_db_object.*
sys_ui_list.*
The tile can be scoped
| ServiceNow admin account | ServiceNow non-admin account with ACLs | ServiceNow non-admin account without ACLs | |
| Being able to scope the tile | yes | yes (due to the ACLs) | yes (due to the web_service_admin role) |
| Being able to see all views in the View dropdown, not only the default view | yes | no | no |
| Being able to see all default filters, not only user-made ones | yes | yes (due to the ACLs) | no |
A Connect edition license (or above) is required for this feature. To upgrade please contact sales@squaredup.com.
To check the license edition you are using see How to check which license key is being used . To see what is included in different product edition licenses see the Licensing Overview.
- In your ServiceNow account in the Application Navigator (left-hand menu) go to System OAuth and click Application Registry.
Dashboard Serverand leave the other default settings as they are. - Once you've created the endpoint, open the entry to view the client ID and client secret. Click the padlock next to the client secret to see it.
- Log on to Dashboard Server and navigate to the right-hand menu ☰ > system > Integrations
- Under Integrations click on Web API, and then OAuth and type in a suitable name, e.g. ServiceNow.
- Change the grant type to password.
- The base URL should look something like
https://instancename.service-now.com/api/now/whereinstancenameis your instance. If ServiceNow is installed on-premises, this may be something different. This URL is prepended to every request URL. - The token URL will be something like
https://instancename.service-now.com/oauth_token.dowhereinstancenameis your instance. - username and password are exactly those used to sign into the account which was setup with the permissions mentioned in the prerequisites.
- client id and secret are taken from the notes you made earlier.
- Leave the authorization scope empty
- Click save.
If the provider is not authorized it could be that some of the provider configuration is incorrect (for example the username, password, secret etc), or if you use a proxy it could be that the proxy is not configured
This walkthrough takes you through configuring a simple tile to show a list of the open incidents.
Take a look at the ServiceNow documentation on the ServiceNow Aggregate API
You can also watch the How to integrate SquaredUp and ServiceNow tutorial Video.
Create a new dashboard and click on the Web API tile.
Select Web API (Grid).
The scope section (v4.2 and above) allows you to specify a scope of SCOM objects (see How to scope tiles), which can be used later in the tile configuration to insert SCOM object properties into the query. For this walkthrough you can leave the scope empty.
If you wish to add a scope you could click on group and search to find a suitable group of computers. You need a group that contains servers monitored by ServiceNow which we can query later.
Or for a perspective for use with Enterprise Applications (EAs), (see Enterprise Applications) you might want to scope to the servers that are specified on the EA map by selecting something similar to the following:
This /<YourApplicationName> Map / ... / Windows ComputerThe above will scope the tile to all the objects of class Windows Computer on this EA's map.
In the provider section select the ServiceNow provider that you created.
In the http mode section paste
table/incidentinto the URL box to make this a GET request totable/incident. This base URL is prepended to the URL.In the headers & data section click add under data to add the following parameters to the request to select the correct data and format for the grid:
name:
sysparm_display_valuevalue:true. This will show the display value of any columns which are IDs by default.name:
sysparm_fieldsvalue:sys_id,urgency,short_description,severity,state,assigned_to. This will only select the fields we are interested in. You can compile a list of fields using the REST API Explorer on your own ServiceNow instance.name:
sysparm_limitvalue:20. This will limit the number of results to the first twenty.name:
sysparm_queryvalue:active=true. This will show open tickets only.
You might like to use one of the mustache style code snippets provided (Dashboard Server v4.2 and above). You'll need to go back and define a scope for the Web API tile first, then you can either start with one of the snippets provided, or write your own dynamic query string. Dashboard Server v4.2 and above support multi-object query building based on a list of objects from the tile's scope, and the use of JavaScript to manipulate the SCOM property values using functions such as
split()andsubstring().When you click the mustache editor button {{}} you will see a list of example scope code snippets, along with the snippet result based on the selected scope context for the tile.
We're working on a dashboard, but the Web API tile scope and dynamic queries can be particularly useful on perspectives. For example, you might like to show ServiceNow asset information for a dynamic list of servers found as children of an Enterprise Application (EA) object (see Enterprise Applications).
In the response data section, paste
resultinto the box.Rows of data should now be shown.
The grid columns and grid options sections allow you to configure the columns and column names.
In the grid columns section, hide the
sys_idcolumn, rename and reorder other columns as you like. Some columns, likeassigned_towill be returned as[object Object]. Click edit next to these columns, and then click the {} icon, then select the display value to have these display correctly.In the grid options section, we can set the row link to make each row hyperlink to that ServiceNow incident. To make each row replace the
sys_idwith the one from that object the URL should behttps://<your-instance>.service-now.com/nav_to.do?uri=%2Fincident.do%3Fsys_id%3D{{sys_id}}For more help customizing the columns of data see How to use the Grid Designer.
Click done.
