Troubleshooting licensing and activation
Frequently Asked Questions
How do I manage user licenses?
What can I do if users are unable to logon?
Troubleshooting users being unable to log on
How do I know which license is currently being used?
Users get an error logging on
Troubleshooting Activation
How do I activate my license?
Which license key do I use to activate Dashboard Server?
How can I activate if my SquaredUp server cannot connect to the internet?
That's fine, you can perform a manual or offline activation on another computer that has got internet access and then copy the .bin activation file onto the server.
See How to activate your license offline (manual activation)
I've been asked to 'reactivate' my license, how do I do that?
You will be asked to reactivate your existing license key, if it has been modified or extended.
See How to reactivate your license
Your Primary Production license key can only be activated once.
If you uninstall and reinstall on the same server and you originally carried out an offline activation (as described in How to activate your license offline (manual activation))then you can reuse the same .bin file by browsing to <SquaredUpURL>/InstallLicense. The .bin file cannot be used on a different server.
For more information see How to activate your license
An error occurred: The key provided is invalid. Activation keys must consist of at least 5 groups of letters and digits
For example:
The activation key you have entered is incompatible with this version of Dashboard Server
The activation key being used is not valid for the version of Dashboard Server.
Please contact SquaredUp Support with details of the problem and the activation key.
This key has expired
